ItooSoft Logo Welcome, Guest. Please login or register.
May 19, 2013, 12:45:30 pm
News:
Itoo Software Forum  |  RailClone  |  RailClone Pro (*)  |  Cones Offset from Spline « previous next »
Pages: [1] Print
Author Topic: Cones Offset from Spline  (Read 486 times)
Mike Truly
Full Member
WWW
« on: April 11, 2012, 11:16:34 am »
Hi Carlos,
I recently bought RailClone Pro and am starting to use it.  (I think it's great!).
I have a road scene and I am using the default traffic cones at 100ft spacing (segment padding 50, 50).  The roadway spline is very simple and straight with a couple of hills.  When I make my railclone of traffic cones, for the most part they are fine but in a couple of spots the cones don't precisely follow the spline and are slightly below grade (see attached image).
I can fix this by converting the railclone to mesh and moving them manually.  The only thing I can think of is that the road spline is very long (several miles) and maybe this scale is causing this?
Logged
Sincerely,
Mike Truly
Truly Media
1.800.829.4990
http://www.trulymedia.com
iToo
Administrator
Hero Member
WWW
« Reply #1 on: April 11, 2012, 01:42:08 pm »
It's a problem of how we have defined this element in the library: we use the Padding to space the cones, but this method doesn't work well for long splines.
Please, do this:
- Set the default Segment to "none".
- Assign the cone to Evenly->Segment.
- Set the distance in Evenly->Distance.
- Set the paddings to zero.
We will fix this object in the library in the next update.
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
carlosqg@itoosoft.com
Mike Truly
Full Member
WWW
« Reply #2 on: April 11, 2012, 03:48:45 pm »
Thanks Carlos!  This fixed the problem.
Thanks again.
Logged
Sincerely,
Mike Truly
Truly Media
1.800.829.4990
Pages: [1] Print
« previous next »
Jump to:
Powered by SMF 1.1.18 | SMF © 2013, Simple Machines
YabbGrey By Nesianstyles | Buttons by A.M.A
