Welcome,
Guest
. Please
login
or
register
May 19, 2013, 03:42:45 am
News:
Forest Pack
Forest Lite
Prevent waterbraker intersect with wall
« previous
next »
Pages:
1
Author
Topic: Prevent waterbraker intersect with wall (Read 383 times)
tonneti
Newbie
on:
May 29, 2012, 04:47:02 pm »
Hi again,
Finally i installed Forest Lite, another "issue" im having (both with MS and Forest) is that i cant prevent the cubes intersect the concrete wall, tried much things in MS and played a bit with Forest with no luck, is some specific option i am missing?
Here my problem:
Administrator
Re: Prevent waterbraker intersect with wall
Reply #1 on:
May 30, 2012, 01:33:50 am »
Use a spline instead a surface, and turn on the Boundary->Size checkbox in the Areas rollout. Forest is optimized to work with splines, and include many specific options for them (as the boundary, falloff and others).
If you reuse the same Forest object with the surface assigned (although in ths case is not needed), remove it or turn off the "Surfaces Area" in the Areas rollout. If not, both areas (the surface and the spline) will be used simultaneously over the same region, creating overlapped objects.
Itoo Software
www.itoosoft.com
carlosqg@itoosoft.com
Pages:
1
« previous
next »
Jump to:
Please select a destination:
Information (read-only)
=> Announcements
Forest Pack
=> FAQ
=> Forest Lite
=> Forest Pro (*)
===> Forest Pro beta
===> Forest Pro - Espaņol
RailClone
=> RailClone Lite
=> RailClone Pro (*)
===> RailClone Pro 2 Beta
===> RailClone Pro - Espaņol
=> Construction techniques
Other boards
=> HQ Plants
=> Other free plugins
=> Image Uploads
=> General - Off Topic
1 Hour
1 Day
1 Week
1 Month
Forever
Powered by SMF 1.1.18
SMF © 2013, Simple Machines
YabbGrey By
Nesianstyles
| Buttons by A.M.A
