Welcome,
Guest
. Please
login
or
register
May 20, 2013, 12:50:58 pm
News:
Forest Pack
Forest Pro (*)
rendering problem when turn forest to custom edit mode
« previous
next »
Pages:
1
Author
Topic: rendering problem when turn forest to custom edit mode (Read 710 times)
PH4128
Newbie
on:
July 26, 2012, 07:41:10 am »
I working on an animation using forest for placing people in a mall. I need to turn forest to the custom edit mode for the final tuning. when forest is turn in edit mode I have render problem with the opacity of the people material (noise in the alpha) see image.
I use vray
someone have an idea?
Thx,
Fred
Administrator
Re: rendering problem when turn forest to custom edit mode
Reply #1 on:
July 26, 2012, 09:44:27 am »
Theorically, there is not difference between generate and custom editom for the material. But checking the image, it seems a coplanar faces issue.
Please, check if for some reason there are two overlapped planes for those billboards.
Itoo Software
www.itoosoft.com
carlosqg@itoosoft.com
PH4128
Newbie
Reply #2 on:
July 26, 2012, 04:09:02 pm »
Hi itoo,
Thx foR your response! I have check, there is no overlapping face. Only 1 face wirh double sided matérial. One image in the diffuse slot and one in the opacity.
I have "slove" the problem by using a forest for each level (one for the ground floor and one for the 1th floor) before there was one forest for 2 level
Administrator
Reply #3 on:
July 26, 2012, 04:27:07 pm »
Ok, anyway if you send us a test scene we would check it.
Itoo Software
www.itoosoft.com
Administrator
Reply #4 on:
July 27, 2012, 05:41:46 am »
Thanks for the file. As i though, there are coplanar items in the 1th floor. You can check it entering in the sub-object mode, selecting a plane and moving it... there is a duplicate item in the same position.
Probably they were created by some copy operation, because the items in the ground floor are correct.
Itoo Software
www.itoosoft.com
PH4128
Newbie
Reply #5 on:
July 27, 2012, 06:47:24 am »
thank you!!!
Pages:
1
« previous
next »
Jump to:
Please select a destination:
Information (read-only)
=> Announcements
Forest Pack
=> FAQ
=> Forest Lite
=> Forest Pro (*)
===> Forest Pro beta
===> Forest Pro - Español
RailClone
=> RailClone Lite
=> RailClone Pro (*)
===> RailClone Pro 2 Beta
===> RailClone Pro - Español
=> Construction techniques
Other boards
=> HQ Plants
=> Other free plugins
=> Image Uploads
=> General - Off Topic
1 Hour
1 Day
1 Week
1 Month
Forever
Powered by SMF 1.1.18
SMF © 2013, Simple Machines
YabbGrey By
Nesianstyles
| Buttons by A.M.A
