ItooSoft Logo Welcome, Guest. Please login or register.
May 23, 2013, 03:55:53 pm
News:
Itoo Software Forum  |  Forest Pack  |  Forest Pro (*)  |  Trees not rendering « previous next »
Pages: [1] Print
Author Topic: Trees not rendering  (Read 376 times)
L&H
Newbie
« on: August 16, 2012, 10:16:56 am »
hi I'm having some issues and need some urgent help. Suddenly my trees have stoped rendering.
I have a forested hilside that references 6 proxies and although the forest appears fine in the viewport it doesn't render at all.
I have other forested objects (grass amd bushes) that render fine. I have checked layer settings, file paths and through all th forest pack setting but I can't get them to render.
Does anyone have any ideas what might be causing this? thanks
Logged
iToo
Administrator
Hero Member
WWW
« Reply #1 on: August 16, 2012, 10:26:27 am »
Please, just after rendering, select the Forest object and click General->Forest Stats. If there is some problem with this object, the dialog box should show more information.
If not, try to isolate the problem, for example using a teapot instead the proxies or rendering the Forest object in a separate scene. Once you have a simple test scene, send us the file and we will check it.
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
carlosqg@itoosoft.com
Pages: [1] Print
« previous next »
Jump to:
Powered by SMF 1.1.18 | SMF © 2013, Simple Machines
YabbGrey By Nesianstyles | Buttons by A.M.A
