Welcome,
Guest
. Please
login
or
register
May 24, 2013, 07:14:24 pm
News:
Forest Pack
Forest Pro (*)
Few features...
« previous
next »
Pages:
1
2
3
4
Author
Topic: Few features... (Read 13578 times)
BB1610
Jr. Member
Re: Few features...
Reply #30 on:
October 08, 2009, 11:30:30 am »
Ah,
sorry to no explain it correctly. I want to add some more forest objects in the areas where FP didn`t create because the bitmap isn`t precise , so I created some closed shapes to add the additional objects, but I cant use them, because the include area of FP is already occupied with shape that cover the whole terrain area. So i propose to make an additional option to define more `include splines / areas`.
-R
Logged
iToo
Administrator
Hero Member
Re: Few features...
Reply #31 on:
October 08, 2009, 12:14:38 pm »
That could be like having multiple splines, each with its own map. Unfortunately, this is very difficult to implement and would involve drastic changes in the interface. I see two solutions for this:
- Use Custom Edit mode to add more trees in the desired areas
- Create additional Forest objects. When finished, you can also attach them to the main object using Custom Edit.
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
carlosqg@itoosoft.com
BB1610
Jr. Member
Re: Few features...
Reply #32 on:
October 08, 2009, 01:11:36 pm »
Thanks for reply,
what about this sitation : add the button to pick `correction spline` when using distribution map in custom map mode, and this spline only add objects based on the distribution map from the predefinied maps ( full, dense, scattered.... ) ?
Logged
iToo
Administrator
Hero Member
Re: Few features...
Reply #33 on:
October 08, 2009, 02:38:57 pm »
We'll take a look to it, although i'm not sure if is possible to use both maps in the distribution process.
Thanks for your suggestions.
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
BB1610
Jr. Member
Re: Few features...
Reply #34 on:
October 08, 2009, 03:07:06 pm »
Thanks very much !
-R
Logged
BB1610
Jr. Member
Re: Few features...
Reply #35 on:
October 10, 2009, 05:21:54 pm »
if object which will be added to the forest has multisub material assigned ( lets mark it as "multisub A" ), then FP assign its own multisub material ( "multisub B" ) to the forest, and this "multisub B" will have as much materials as is the highest ID number in "multisub A" , so if you have in reality in "multisub A" just 2 materials which one if have id=999 , then "multisub B" will consist of 999 materials. Coudl that be corrected ? This may look as silly request, but in complex scenes with complex multisubs, it`s hard to navigate in multisubs created by FP.
Logged
iToo
Administrator
Hero Member
Re: Few features...
Reply #36 on:
October 11, 2009, 03:35:35 am »
When you create a multisub which has a single material with an ID of 999, Max creates internally a multisub with 999 materials: 1 material + 998 unused (you can verify it using Maxscript). To hide the unused materials, it uses the property "materialIDList" that contains the list of materials in use.
But, i'm not sure why, this property is not accesible from the plugins using the SDK (although it is from Maxscript). Because this, we cannot hide from Forest all those unused materials.
I just wrote a email to Autodesk asking about this issue. If they give us a solution, we will fix it for the next patch.
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
BB1610
Jr. Member
Re: Few features...
Reply #37 on:
October 12, 2009, 06:39:15 pm »
Wonderfull
I have a next question, it is not related directly to the purpouse of FP, but only about its part. When we have a lot of unique hipoly object which haven`t been placed by FP, we tend to hide the ones which aren`t in the frameview. We do it quite often, and I though if FP could have a minor `offspring` which basically do this : select object from objectlist, or from selection, and then use the FP function "camera - area - limit to visibility" to that objects. It would save a ton of time.
Radomir
Logged
iToo
Administrator
Hero Member
Re: Few features...
Reply #38 on:
October 13, 2009, 12:43:15 pm »
Forest hides automatically from render the custom objects (if "Display->Hide Custom Objects..." parameter is enabled). You would to create a dummy Forest object (as instance, using a very small area spline) and assign all meshes to it, that would to work.
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
BB1610
Jr. Member
Re: Few features...
Reply #39 on:
October 16, 2009, 06:08:51 pm »
Quote from: Itoo on October 13, 2009, 12:43:15 pm
we misunderstood each other, I meant, that this `program` - based on FP, will load a geometry from scene ( for example houses which are placed on exact positions , not by FP ) and it will use the "camera - area - limit to visibility" function on them. So if you have for example - thousands of houses placed in scene NOT by FP, but manually - then this `program` will hide unnecessary houses - based on FOV of the camera ( as is "camera - area - limit to visibility" )
-R
Logged
iToo
Administrator
Hero Member
Re: Few features...
Reply #40 on:
October 17, 2009, 02:22:37 am »
Ah, ok. I though that you want to hide from render the objects used as custom meshes, although they not be assigned to any Forest object.
About your suggestion, it could to be a new plugin. I will think on it ...
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
BB1610
Jr. Member
Re: Few features...
Reply #41 on:
October 17, 2009, 05:13:29 am »
Quote from: Itoo on October 17, 2009, 02:22:37 am
Aww, that`s wonderful new, hope , really hope that you`ll not just think of it, but, actually make it happen
Logged
iToo
Administrator
Hero Member
Re: Few features...
Reply #42 on:
October 17, 2009, 05:27:35 am »
Well, the big problem about writing new plugins are not the technical issues, but how to get time for all planned projects...
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
BB1610
Jr. Member
Re: Few features...
Reply #43 on:
October 17, 2009, 11:49:47 am »
Quote from: Itoo on October 17, 2009, 05:27:35 am
Tell me something about it , in fact, if I could, I`ll buy spare time from others who doesn`t need it.
Logged
BB1610
Jr. Member
Re: Few features...
Reply #44 on:
October 23, 2009, 03:44:44 pm »
Hi, another feature that would be great :
Density/Size fallof working also on bitmaps,not just on splines.
Logged
Pages:
1
2
3
4
« previous
next »
Jump to:
Please select a destination:
Information (read-only)
=> Announcements
Forest Pack
=> FAQ
=> Forest Lite
=> Forest Pro (*)
===> Forest Pro beta
===> Forest Pro - Espaņol
RailClone
=> FAQ
=> RailClone Lite
=> RailClone Pro (*)
===> RailClone Pro 1.x
===> RailClone Pro Beta
===> RailClone Pro - Espaņol
Other boards
=> HQ Plants
=> Other free plugins
=> Image Uploads
=> General - Off Topic
1 Hour
1 Day
1 Week
1 Month
Forever
Powered by SMF 1.1.18
SMF © 2013, Simple Machines
YabbGrey By
Nesianstyles
| Buttons by A.M.A
