Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Tree Darkening Problem
« previous
next »
Print
Pages: [
1
Author
Topic: Tree Darkening Problem (Read 12332 times)
Mike Truly
Full Member
on:
July 05, 2007, 04:23:18 PM »
I have this problem quite often and I'm wondering what I'm doing wrong or what can be done about it.
I create a wide view of trees (for example in a mountain scene) and there are thousands of trees but they are very dark looking... almost black. The material used is a standard MAX material using trees from the Forest Pro library. The material is 100% self illuminated, yet the trees are almost black. The nearer trees look OK but a little dark. The far trees seem to look black.
Attached is an image showing what I get. I can adjust the Output rollout of the bitmap but have not really found the ideal settings yet.
Thanks for any ideas!
Sincerely,
Mike Truly
Truly Media
1.800.829.4990
http://www.trulymedia.com
Administrator
Re: Tree Darkening Problem
Reply #1 on:
July 05, 2007, 04:52:50 PM »
Hi Mike,
I just done a test scene using a material 100% self illuminated, but i don't get that black trees (and the texture that i've used is very dark).
Please, send me your scene to play a bit with it (only trees, camera, lights and so).
Last Edit: July 05, 2007, 04:54:36 PM by Itoo
DIMITRIS
Full Member
Reply #2 on:
July 05, 2007, 04:59:42 PM »
I have a photo that looks exactly like your black trees... It can be partially a contrast issue that fools the eye... I would like to see a blowup rendering of your scene, then it might be clear.
Our admin didn't use snow for the test so that's why there is such big difference...
Maybe I'm wrong but I think this is important too.
Last Edit: July 05, 2007, 05:01:39 PM by JTB
I will sign it only if it is a piece of art!
Administrator
Reply #3 on:
July 05, 2007, 05:13:30 PM »
Yes, it may be a optical effect too. Please see this photo:
http://sinope.redjupiter.com/images/bobrat/RotationofResizeofff007.jpg
Last Edit: July 05, 2007, 05:15:19 PM by Itoo
Mike Truly
Full Member
Reply #4 on:
July 05, 2007, 05:25:47 PM »
Carlos and all,
Thanks for the ideas. Actually, that image just looks like snow but is actually just a light blue background with the terrain hidden.
Attached is a zipfile with the FP trees and other items. The terrain is not included as it's gigantic and I can't share that.
It may be an optical illusion as the scenes I create are very large. I have found a work around by using a falloff map in the diffuse slot which will use the tree bitmaps near and just a solid color far away (the tree OMAP is still being used for far away). This allows the far trees to show up brighter with color. But it seems to be an issue of many tree bitmaps at far distances turning black because my 'falloff' method shows that color can be shown at long distances. You'll also see that I have cranked the video level of the bitmaps to try to get them to be brighter. (If you turn off the video level back to 1.0, you'll see the trees get darker).
Thanks for looking at this!
Sincerely,
Mike Truly
Truly Media
1.800.829.4990
Mike Truly
Full Member
Reply #5 on:
July 05, 2007, 05:29:12 PM »
Oh and here's a render from the perspective view without the terrain. You can see the dark tree effect as well as my improvements with falloff where the far color is showing when it's faded to color and no bitmap.
Sincerely,
Mike Truly
Truly Media
1.800.829.4990
DIMITRIS
Full Member
Reply #6 on:
July 05, 2007, 05:33:12 PM »
My small Maxwell sample... No conifers so everything is much brighter
Administrator
Reply #7 on:
July 05, 2007, 10:43:46 PM »
Mike,
Definitively is a effect of the texture when applied over very small objects.
What about if you use a Random Tint ? It allows to modify the overall color without modifying the materials:
Last Edit: July 05, 2007, 10:46:14 PM by Itoo
Mike Truly
Full Member
Reply #8 on:
July 06, 2007, 03:20:25 PM »
Carlos,
Thanks for the ideas. I may try that. I am not currently using the Planes material but this would be a good case. For my situation, I think my current method of using falloff works pretty well because I only have to setup one set of FP Trees or materials since I can view the real tree bitmaps of trees when they are near the camera (camera close to trees) and have it fade to color only far away.
This lets me setup the scene once, and then I see tree bitmaps up close but green tree illusion far away.
Thanks again.
Sincerely,
Mike Truly
Truly Media
1.800.829.4990
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
