Author Topic: RailClone Pro 1.1.0 beta  (Read 11581 times)
« on: January 31, 2011, 08:10:14 PM »
Note 2: New .dll files has been included on this release to provide VRay support: RailCloneVRay150sp3.dll and RailCloneVRay20.dll. These files are installed by the setup program in the Max root folder.
New features:
- CPU Multi-core support. Global performance have been improved
- Proxies and high-poly meshes support for VRay:
    * Lets you to render huge number of high-poly objects using minimal resource
    * Proxies and objects are converted on the fly to native render instances
- Mapping Coordinates (Randomness rollout)
   * Avoid texture tiling, applying box mapping to the Segments along the path
- New "Display" rollout:
    * Configurable "Boxes" mode for Viewport and Render
    * Adaptative mode. Use "Boxes" mode on viewport if the number of faces specified is exceeded
    * "Boxes" display mode is more accurate respect to the full geometry
    * Render mode: Automatic mode uses native instances for VRay or Mental Ray. Meshes mode creates a unique mesh for the geometry
    * Build button and Max.Faces and Max.Segments parameters have been moved from the General rollout here
- Fixed geometric issues when applying both random rotation and scale
- Bevel works properly on splines with collinear vertices
- Geometry->Copy From/To works properly on RailClone objects with modifiers
- Fixed minor Library Browser issues
RailClone Pro registered users can download the software from the User Panel (My Betas section).
Sample scene using huge RailClone geometry with VRay
« Last Edit: January 31, 2011, 08:20:38 PM by Itoo »
