Welcome,
Guest
. Please
login
or
register
May 23, 2013, 02:39:18 pm
News:
Forest Pack
Forest Lite
Compact Material Editor Problem
« previous
next »
Pages:
1
Author
Topic: Compact Material Editor Problem (Read 900 times)
Argyll
Newbie
on:
October 30, 2011, 04:46:42 pm »
I opened the grass tutorial and it worked fine, however, when I opened the material editor and tried to create a new material I get a Parameter error as shown in the attachment. If I click on the material button in order to change it from Standard to something else I get the same error and eventually after 4 or 5 attempts, 3ds max (2012) crashes. If you can't create materials in the material editor..... that's a real problem.
Logged
iToo
Administrator
Hero Member
Re: Compact Material Editor Problem
Reply #1 on:
October 31, 2011, 03:39:55 am »
I cannot reproduce the problem here (Max 2012 64 bit, Forest Lite 3.6.0), so there must be some difference with your configuration.
What version of the tutorial have you downloaded, Mental Ray or VRay ?
Do you have VRay installed ?
Do you get other errors or warning messages while loading or rendering ?
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
carlosqg@itoosoft.com
Argyll
Newbie
Reply #2 on:
October 31, 2011, 04:43:03 am »
I'm using mental ray and can produce this error almost at will. I had it happen four times in a row yesterday and once today. I have the latest service pack for 3ds max 2012 installed so don't know if that's causing a problem. Also, I'm running a 32 bit app on 64 bit W7, so it may be a bit flaky. I really like what the software does and will probably purchase the pro version as I'm gradually coming to terms with it, but this type of crash is a bit of a worry.
Logged
iToo
Administrator
Hero Member
Reply #3 on:
October 31, 2011, 06:22:32 am »
So, did you get this error also working with other scenes, not only the grass tutorial ?
It seems there is some file corrupted in Max (because the "File Open Error" title of the error dialog), probably something related with the materials.
If you are worried about whether Forest Lite is triggering this error, i would suggest uninstall the plugin temporary and see if the problem remains. Sincerely, seeing the symptoms, i think this error is not caused directly by Forest. Similar issues have not been reported by other users either.
Logged
Carlos Quintero
Itoo Software
www.itoosoft.com
Argyll
Newbie
Reply #4 on:
October 31, 2011, 07:31:42 am »
The error was with every scene. I've reinstalled 3ds max and Forest Lite and everything now seems to be working fine so I guess and it's only a guess, that one of the 3ds max files was corrupt - I got the error after uninstalling Forest Lite and running 3ds max on its own.
Logged
Pages:
1
« previous
next »
Jump to:
Please select a destination:
Information (read-only)
=> Announcements
Forest Pack
=> FAQ
=> Forest Lite
=> Forest Pro (*)
===> Forest Pro beta
===> Forest Pro - Espaņol
RailClone
=> FAQ
=> RailClone Lite
=> RailClone Pro (*)
===> RailClone Pro 1.x
===> RailClone Pro Beta
===> RailClone Pro - Espaņol
Other boards
=> HQ Plants
=> Other free plugins
=> Image Uploads
=> General - Off Topic
1 Hour
1 Day
1 Week
1 Month
Forever
Powered by SMF 1.1.18
SMF © 2013, Simple Machines
YabbGrey By
Nesianstyles
| Buttons by A.M.A
