Recursos
Requerimientos
- info RailClone Pro
Productos destacados
Obtener Productos
The library is designed so that users do not need to open the graph editor. All the necessary controls are exposed in the Base Objects and Parameters rollouts.
To create a building
Draw a spline. Use a closed spline for a complete building, or an open spline if you only require a facade (like a film set). When you are creating splines, be aware of the vertex type. Corner vertices should be used to create hard corners, Smooth and Bezier Corners can be used to create curved buildings. The latter two vertex types will not generate corner geometry.
Create a new RailClone Object and open the Library. Select one of the single building presets and click Import Selected.
Go to the Base Objects rollout and select Spline from the list. Go to the Properties and assign the splines selected in the first step.
To change the building's properties, go to the Parameters rollout where you'll find the editable properties for each asset.,Several properties are common to all buildings, while some are unique. You can see a list of the parameters for each building in the documentation.
