Using ParametricLibrary All-In-One Background Building Presets
How to use the all-in-one building presets including in our ParametricLibrary Background Buildings collections.
Требования
  • info RailClone Pro
play_arrow
In addition to 13 fully parametric individual towers, the collection also includes an all-in-one preset that's designed to quickly and efficiently fill large areas. To use it.
  1. Create a new RailClone object and open the Library Browser. Select and load the All-In-One preset..
  2. To edit the object, all the settings can be found in the Parameters and Base Objects
  3. The most important settings are the X and Y size parameters which allow you to specify the grid size of the buildings
    It's also possible to use a spline for the X axis should you need a layout that follows a straight or curved path. 4. Information about the presets many other parameters are shown in our documentation.
Другие руководства
Installing ParametricLibrary Background Buildings collections
how to install our ParametricLibrary Background Buildings collections so that they're at your fingertips when you need them in the RailClone library browser.
