Ask iToo January 2023 Livestream
Watch the recording of our January 2023 Livestream
play_arrow
Main topics this month included:
00:01:00 Forest Pack 8.0.7
00:02:46 How to add a column where splines intersect using RailClone
00:09:13 How to rotate in increments in Forest Pack
00:11:25 How to model a perforated brick wall with RailClone
00:17:27 How to debug styles using the Stats window in RailClone
00:24:40 How to scale items in Forest Pack to fit under a stair case (or some other surface above)
00:33:11 How to use a different distribution map for each surface in Forest Pack
00:36:38 How to create ivy hanging from the top of a wall. An introduction to GrowFX and combining GrowFX assets with Forest Pack
01:01:05 How to overlap corners instead of slicing them with RailClone (for example to create raised beds from railway sleepers)
Other Tutorials
Force Open Spline
Learn how to force Forest Pack to use closed spline as open spline
Autumn Leaves
10 Second Tip: In Autumn, leaves go brown in patches. Here's how you can create this effect in Forest Pack.
