Ask iToo RailClone 6 Livestream. Learn all about the great new features
Watch the recording of the RailClone 6 features tour
  • Home
  • Ask iToo RailClone 6 Livestream. Learn all about the great new features
Requirements
  • info RailClone 6 Lite or Pro
play_arrow
Recorded on Tuesday 30 May 2023, this special livestream Q&A session explains nearly all the new features of RailClone 6, including:
  • 00:03:15 Introduction
  • 00:05:19 New Libraries
  • 00:11:46 how to use the always-on-top style editor
  • 00:15:44 RailClone Basics and the new RailClone Slice modifier
  • 00:36:22 how to quickly add your custom RaiLClone styles to the library
  • 00:39:40 How to use the improved Group features
  • 00:48:00 Style Editor Improvements
  • 00:49:11 How to control automatic segment naming
  • 00:50:20 How to assign geometry to multiple segment nodes
  • 00:52:00 How to clone nodes using shift+drag
  • 00:55:20 How to automatically convert scene objects to segments
  • 00:58:00 How to choose between open and closed doors using a Selector node
  • 01:00:20 new marquee select options
  • 01:01:17 New value list node
  • 01:03:26 How to change the thickness of wires in the Style Editor
  • 01:03:45 Boolean AND/OR in conditional nodes
  • 01:04:50 Using Link and Reroute nodes to organise graphs
  • 01:09:18 How to convert an existing graph to macro
  • 01:12:16 Saving presets for drop down lists
  • 01:13:50 How to limit generators using comma separated lists or ranges of material IDs
  • 01:17:06 New segment and number randomisation options
  • 01:22:46 Using the new new Free marker type
  • 01:27:45 Using deformation modes on segments below the X Spline
  • 01:33:35 How to password protect RailClone styles
  • 01:35:23 How to UV map and assign material IDs to capped faces
  • 01:37:39 How to assign user attributes to instances distributed with RailClone
  • 01:40:33 Outro and invitation to the next webinar
Other Tutorials
Clipping Splines
10 Second Tip: Use clipping splines to cut window apertures through siding and facades.
Increment/Decrement Values Along a Spline
Learn how to change any property based on a segment's position along the base spline.
