Rendering road markings in 3ds Max
Learn how to combine RailClone with Distance Texture maps to render road markings
play_arrow
In this tutorial, we’re going to use RailClone in conjunction with V-Ray distance texture  to create several different types of road markings. Including a solid single line, a dashed single line, a double solid line, a double dashed line, a dashed and solid line, and its opposite, a solid and dashed line. We’ll also create a style that can fill areas with a lined outline.
It goes without saying that this style is fully parametric, and once created it can be used again and again. Unlike decals, it can also efficiently create markings of any shape
The majority of this tutorial can be done with the free Lite version of RailClone, and if you just want to use the finishes style and aren’t interested in learning how it was created, you can simply download it from our website and just follow the section explaining how to set up the materials.
Have fun!
Other Tutorials
Graduated Colour Probabilities
10 Second Tip: Creating tiles in RailClone with a randomised and graduated transition between colours.
Clipping Splines
10 Second Tip: Use clipping splines to cut window apertures through siding and facades.
