Requirements
- info RailClone Pro
In addition to 13 fully parametric individual towers, the collection also includes an all-in-one preset that's designed to quickly and efficiently fill large areas. To use it.
Create a new RailClone object and open the Library Browser. Select and load the All-In-One preset..
To edit the object, all the settings can be found in the Parameters and Base Objects
The most important settings are the X and Y size parameters which allow you to specify the grid size of the buildings
It's also possible to use a spline for the X axis should you need a layout that follows a straight or curved path. 4. Information about the presets many other parameters are shown in our documentation.
